MACsec.PDU.ParmSetBasic
Description
This message displays the contents of a transmitted or received MKPDU's Basic Parameter Set Each MKA PDUs (MKPDU) contains a sequence of "parameter sets": Basic, Live Peer List, Potential Peer List, SAK Use, Distributed SAK. The Basic Parameter Set is mandatk/ory. MKA Version: 1: IEEE802.1X-2010 Key Server Priority: 0..255, lower value is higher priority Key Server: set if and only if the participant has not decided that another participant is or will be the Key Server MACsec Desired: set if participant desires the use of MACsec to protect frames MACsec Capability: 0: MACsec not implemented 1: Integrity without confidentiality 2: Integrity, confidentiality with offset 0 3: Integrity, confidentiality with offset 0, 30 or 50 SCI: Secure Channel Identifier MI: Actor's Message Identifier MN: Actor's Message Number Algorithm Agility: 0080C201: IEEE Std 802.1X-2009 CKN: CAK Name Further details on MKA parameter sets and parameters can be found in Clause 11.11 EAPOL-MKA of IEEE Std 802.1X-2010.
Remedy
No action required - Informational message only.
Severity
Debug-Verbose
Message Text
%direction% MKPDU on port %slotPort% [Basic] MKA Version:%mkaVersion% Priority:%keyServerPriority% Key Server:%keyServer% Desired:%macsecDesired% Capability:%macsecCap% \nSCI:%sci% MI:%memberId% MN:%msgNum% Agility:%algorithmAgility% CKN:%ckn%
Message Parameters
Name Type
slotPort SlotPort
direction String
mkaVersion uInt
keyServerPriority uInt
keyServer uInt
macsecDesired uInt
macsecCap uInt
sci HexNosByteArray
memberId HexNosByteArray
msgNum uInt
algorithmAgility HexNosByteArray
ckn HexNosByteArray
Applicable Platforms
